I've recently started getting into SMD work, and have decided it's time to invest in a set of 0805 resistors. I'm getting one of the E12 sets on eBay: if the set doesn't state itself as E12 then some less-used values like 39r are left out. I will have 86 different values of resistor (7 sets of 12 + 10M and 0). There seem to be several solutions out there; I'm thinking of
this because I would be able to remove the vials when I am using them, and re-arrange the order if necessary. I could also buy some vials on eBay and fill them with components, then put them in my (currently) through-hole component drawers.
There seem to be several pill boxes advertised as smd organisers, I could remove the day of the week label with isopropanol alcohol / acetone although there would still be the irritating Braille. Of course, the other concern is the lid - it looks as though the components could easily fall through the fingerhold!
Here is an example. I saw
this which has 144 bins for components, but I wouldn't be able to remove the individual boxes / bins. The last thing I saw was
this, which is a set of 50 snap-together boxes (I believe they're also available at Adafruit). They would also be good.
What do you suggest / use?
