Author Topic: Soldering station!?  (Read 7890 times)
Offline Pexy13Topic starter
  • Country: hr
Soldering station!?
« on: May 11, 2017, 11:30:40 am »
Greetings.
I am planing to buy myself a new soldering station because my cheap (light dimmer style circuit) died.
You don't need to tell me to buy a hakko or weller because I live in Croatia and you have to give an arm and a Di*k to buy one.
So... was searching online and came across these:
http://www.tme.eu/hr/details/pensol-sr976/lemne-stanice/sorny-roong-industrial/
http://www.tme.eu/hr/details/pensol-sl10-n/lemne-stanice/sorny-roong-industrial/
http://www.tme.eu/hr/details/pensol-sl10e-n/lemne-stanice/sorny-roong-industrial/
http://www.tme.eu/hr/details/pensol-sl20c/lemne-stanice/sorny-roong-industrial/
Have you heard of this soldering stations and are they any good?
Witch one would you buy and why.
If you have any other recommendation please tell me (nothing more than 150$)
THANKS
Offline stj
Re: Soldering station!?
« Reply #1 on: May 11, 2017, 12:06:42 pm »
those Solomon units are junk.
look on banggood for a bakon bk950d
Offline rustybronco
« Reply #2 on: May 11, 2017, 12:45:36 pm »
A co-worker has the Yihua 937d+ and it appears to be a good unit.
Another option would be a clone T12 handle and a 'controller' for it.
Offline P90
« Reply #3 on: May 11, 2017, 01:16:04 pm »
Yihua 937d
Offline wraper
  • Country: lv
« Reply #4 on: May 11, 2017, 01:58:18 pm »
Greetings.
THANKS
All of that is junk. As you are in Europe, get ERSA I-CON pico https://www.amazon.de/Ersa-i-CON-Digitale-L%C3%B6tstation-0IC1300/dp/B008HPD0L6/ref=sr_1_1?ie=UTF8&qid=1494511013&sr=8-1&keywords=i-con+pico
  • Country: hr
« Reply #5 on: May 11, 2017, 03:48:33 pm »
What about yihua 939D?
  • Country: hr
« Reply #6 on: May 11, 2017, 03:49:42 pm »
Did you have one or just talking without proof?(no hate)
  • Country: hr
« Reply #7 on: May 11, 2017, 03:50:47 pm »
Nicee. I will have it in mind but will still look.
Offline wraper
  • Country: lv
« Reply #8 on: May 11, 2017, 04:03:52 pm »
Not as bad than those solomons but not good either. Passable knockoff is still a knockoff.
Offline frozenfrogz
  • Having fun with Arduino and Raspberry Pi
« Reply #9 on: May 11, 2017, 04:07:26 pm »
I don’t know if they will ship to Croatia and how much it would be, but you could get the Hakko FX-888D for 98€ at http://www.batterfly.com/shop/hakko/hakko_fx-888d right now. Edit: -> From Italy that is.
Sretno!
Frederik
He’s like a trained ape. Without the training.
Offline cyrus8052
« Reply #10 on: May 11, 2017, 04:20:37 pm »
I know you don't have a soldering iron. My post is counter intuitive. If you can borrow one temporarily and wish to take DIY route, take a look at the following link
http://dangerousprototypes.com/forum/viewtopic.php?f=56&t=7218
Probably it may be little over your budget. Initially, you can stick to a clone of Hakko 907. Later you can consider buying a JBC T245 handle and couple of cartridges. Recently I bought a T245 handle for $45 and couple of cartridges for $13.50 ea on eBay, for the station I am building.
Offline stj
Offline wraper
  • Country: lv
« Reply #12 on: May 11, 2017, 04:26:17 pm »
Sretno!
Frederik
98 + 38 shipping + 22% VAT = EUR 166. Way more expensive than I-CON pico and almost approaching price of I-CON nano (if you need ESD safe) https://www.amazon.de/Ersa-i-CON-Digitale-L%C3%B6tstation-0IC1200A/dp/B002MQLJ46/ref=sr_1_1?ie=UTF8&qid=1494519885&sr=8-1&keywords=I-con+nano which is way way better.
Offline cyrus8052
« Reply #13 on: May 11, 2017, 04:28:37 pm »
you can get pcb's, or a kit for that.
http://www.ebay.co.uk/itm/Universal-soldering-controller-for-Hakko-JBC-and-etc-soldering-UniSolder-5-2-/222478565688
@Pexy13, If you wish to build one, probably you should check on this forum. Someone might have PCB's to spare.
  • Country: hr
« Reply #14 on: May 11, 2017, 05:56:45 pm »
unfortunately I Would like to buy it but it would cost me 166$
  • Country: hr
« Reply #15 on: May 11, 2017, 06:01:12 pm »
Offline frozenfrogz
« Reply #16 on: May 11, 2017, 06:07:47 pm »
Wow. That’s :scared: :scared: :scared: :scared: :scared:
  • Country: hr
The following users thanked this post: frozenfrogz
Offline frozenfrogz
« Reply #18 on: May 12, 2017, 09:40:00 am »
You will not be regretting this :)
The Pico is about the same high performance as the Nano minus ESD safety.
Enjoy your new tool!
Offline LordKING
« Reply #19 on: May 12, 2017, 10:31:22 am »
Pico doesn't have grounded tip, but you can hack it: https://youtu.be/ZT8HsC8ewzc
Offline wraper
  • Country: lv
« Reply #20 on: May 12, 2017, 10:41:06 am »
Yes, Nano has exactly the same PCBs inside the station and soldering iron. The difference is different heating element and no ground wire from mains wire to the main PCB. Also could be non ESD safe plastic for the case and soldering iron, but that needs to be tested. On the other hand, it's not said that OP has grounded outlets in his home in the first place.
Offline P90
« Reply #21 on: May 12, 2017, 11:27:57 am »
run a jumper wire to a cold water pipe...there's your ground...    :>)
