Hey everyone... I'm new here so hopefully I put this in the right place.
I've somehow gotten into the position where I'm looking at upgrading 10 university soldering stations (shared by ~100 students, >70% haven't soldered before). They're an absolute mess right now, but we don't have a ton of money to fix them up. We do have about 12 Weller WR2's and 6-8 WES51 units. (As well as a 5 of the cheap sparkfun stations, non-hakko). I've got a few years experience soldering, and I've looked through Dave's first tutorial for tool recommendations, here's what I've compiled.
Most of the work is through hole, so I'd like to keep 8 stations for that, and 2 for surface mount work. We don't have the resources to do 10 stations for both.
For all the stations, I'm thinking
- Some sort of Tool Organizer
- Good Flush Cutters
- Flat Needle Nose Pliers
- #2 and #5 Solder Wick
- Flux Pen or 2 (non 'No Clean')
- Acetone/Isopropyl
- Brushes
Various wire sizes, strippers (the wire kind), and maybe things like dental picks would be available but not left out for general use, we have a system to handle that already in place.
For the Through Hole Stations, in addition,
- Weller WR2 (Soldering/Desoldering Irons)
- Medium and Large Chisel Tips
- 0.4mm and 1mm Solder
- Jeweler's Loupe or Handheld Magnifying Glass
For the Surface Mount Stations,
- Weller WR2 (Soldering Iron/Hot Air Wand)
- Fine and Medium Chisel Tips
- Very Fine Conical Tip (we stock Schmart Boards...)
- 0.4mm Solder
- Non-Locking Tweezers
- Stereo Microscope
What I'm not sure about...
- Are round nose pliers useful? Locking Tweezers?
- How about wicking tips?
- Weller Hot Air Wands... I've only ever used the larger style, are they equivalent?
- There's about 8 WES51's left unused, what could we do with them?
- Most of the PCBs are immersion tin finished, so I'm looking for mildly active fluxes, is that alright? They're generally newly finished PCBs.
- I have a tool organizer from Omni, it's plastic and has slots to hold often used tools, is there something similar out there you can just buy of the shelf?
- What am I missing?
So, what would you do in this situation? Anything's welcome.. Brands, tools, wish lists, general advice, ridicule, etc.
