I'm curious as to how this turned out. Did you end up going with the Ersa? If so, how do you like it?
I did go with the Ersa from toploser. I've been using it ever since. It works great. I had some issues getting parts at first (Ersa NA were useless to deal with, they tried setting up their own webstore and failed miserably, and a number of US parts suppliers wouldn't ship to me for reasonable rates (I'm in Canada)). Eventually though Ersa NA got better to deal with and I found murraypercival.com good to get parts for, even if sometimes you have to call.
The station is incredible. I've had a chance to use the JBC since then and I liked it but I prefer the Ersa. The tips last forever, temps are very stable, it's easy to update the firmware, and I prefer the feel of the hand pieces. That said, the JBC is very nice too. And parts are easier to come by.
I'm in a similar situation but trying to stay under $2250. My options: JBC DME with T210, T245, T120 Tweezers, and up to $750 for a good hot air station. Second option, The Ersa Vario 4 on Farnell plus a micro iron (not sure if Ersa has one for the Vario series). I may have to pickup a separate Nano unit.
FYI: I do what would generally be considered micro soldering (down to the level of 5S long screw damage repair, which is 75 micrometer wide traces, or around the thickness of 40AWG wire) and have no issue with the standard Ersa hand piece, so you may not either. It really comes down to if it's comfortable for you. The tips should allow anything within reason
I do a range of work (iPad backlights, iPhone Touch IC, Macbook board repairs, DC jacks, PS4 HDMI ports, etc, etc). So, pretty big to very small components. Definitely need a high powered hot air station for items like the HDMI ports and also a micro iron for the tiny pins.
People who use JBC seem to all love them. However, people who have also used Ersa say that they do generally prefer them to JBC. Mostly, I'd like to know if it's even still possible to actually get the Ersa in this price range. Any info would be well appreciated! Cheers
I do much of the same type of work. I wouldn't really describe any of that as micro soldering, so a true micro iron would likely be unnecessary, and for anything with a large pad attached it won't work well anyway (heatsink).
For the ICs and jacks/ports make sure to invest in a good preheater with external temp sensor. Makes a world of difference.
For a high volume hot air station I'd look at the Quick 861DW. A forum member turned me on to it. Cheap but seriously over performs. I also own a Weller 3000 rework station and the 861DW performs nearly as well as Weller (minus programming) which costs 10x as much.
I'm actually closing shop fairly soon and 'retiring' to a more rural location so I might end up selling off some of the equipment I've got. I've got a bunch of OCA LCD refurbishing equipment too. If you're looking at used equipment as well as new pop me off a PM and we might be able to work out a deal, depending on your location.
