Hi!
I'm trying to modify my Aoyue SMD workstation, and add hose spliter and extension so I can use both SMD pickup tool and fume extractor. Does anyone knows where I can find similar hose like they use? It's super flexible, I'm guessing 6mm ID 8mm OD and wall thickness about 2 mm... So far all I can find are very stiff hoses... Preferably in USA or China
i use a ghetto method. washing machine water exhaust flexi pipe (or the aluminium version if you fancy) + a centrfugal DC fan in a double box assembly, one of the sides stick to my window and does exhaust. so the pipe is like a DC vac you can stick onto gassing areas.
if you have seen chemical labs, they have those glass boxes for mixing dangerous fuming chemicals, i got the inspiration from that.
i have also bought a mini pump which i could mod for smd sucking. imo, if the pressure is too great, use a smaller needle tip,
http://g02.a.alicdn.com/kf/HTB16Df4IFXXXXbJaXXXq6xXFXXXW/12pcs-Blunt-Stainless-Steel-Dispensing-Adhesive-Glue-Syringe-font-b-Needle-b-font-Tip-12-font.jpg. i have yet to do suction placement, so my info here could be way way off
but on the other hand, i have a mechanical arm that position this sucking head. so it is hands free. you will need to think of a way to fixate the suction pipe on your end. or just freestand the centrifugal fan and blow it into a cloth bag of cotton wool
