If you keep the microscope at normal room temperature, fogging is not suppose to happen.
My no name microscope never gets foggy, but I don't think I ever used it continuously for more than a half an hour.
Fog and condensation forms only when the air get colder.
- when is warm, the water solubility in air is big, so a lot of water vapors (humidity) will be suspended in air
- when the temperature decreases, the water solubility also decreases, so less water vapors can float in the air
- the excess water vapors from when the air was hotter will need to go somewhere, so condensation will start to happen
- the temperature at which, for a given air humidity, the water start to condensate is called 'Dew Point'
Of course, breath will almost always be a source of hotter and humid air, so the 'Dew Point' from an exhalation will almost always produce condensation on the room temperature objects.
