I do NOT envy the guy doing the disassembly, with so many people watching. Especially when it became difficult due to the screws seized from impact deformation.
Hands up who else can use tools skillfully enough, unless someone is watching - in which case you become an apparently incompetent stumblebum?
Also to have to resort to hammering and drilling, in that situation... awkward.
Heh, and they really didn't expect that. At 19:09, that looks like a concrete nail he's using to centerpunch the head of the screw, to drill it out. Well it works...
So amusing to see all the members of the press, bored to distraction by having to wait a few minutes while some guy drills out a few screws.
Weird they didn't have a small vacuum cleaner, to suck the insulation dust out of the recorder as they dug down inside it. You'd think they'd expect that. Since this is supposedly a room used for many international flight recorder accident investigations. Had to bring a standard vacuum cleaner in from outside.
Hmm... All three nested cases are cast alloy, and quite thick. With compressible insulation between them. That would probably be good enough for impact damping from an aircraft hitting the ground. But that hole in the outer case was made by a high velocity shrapnel from the missile, and it looks like it penetrated to and damaged the second casing as well. Hence the seized screws in that one's lid. I guess that explains the extremely high G forces that smashed the boards and chips. The direction of breakage is consistent with a high G impulse due to the case penetration impact. On the underside of the bottom PCB, the flash chips pulled away from the PCB by their own mass... I wonder what the actual G force is, required to do that?
It's a pity. The Russians know their plane never entered Turkish airspace, and the shootdown was a prepared ambush with no justification. But it would have been useful to be able to prove it via indisputable public process.
At least they still scored points for opening a black box in public, as opposed to the total secrecy of all such Western investigations in recent decades.
