Author Topic: Tayda review (First package)  (Read 10644 times)
Offline StonentTopic starter
« on: November 07, 2013, 08:44:37 am »
Well had placed an order with Tayda on 11/1 late at night and received it on 11/6. Pretty darn good I'd say.
Some people said that Tayda was based in Thailand but this package has a return address of
Airbiz2555
510 Ridgeview Dr.
Louisville, Colorado 80027
I put it into google maps and found this
https://maps.google.com/maps?ie=UTF-8&layer=c&z=17&iwloc=A&sll=39.963484,-105.157944&cbp=13,14.5,0,0,0&cbll=39.963270,-105.158017&q=510+ridgeview+dr+louisville+co+80027&ei=lk57Urb9OMXJkAfOhIH4Cg&ved=0CCsQxB0wAA
It looks like a residential neighborhood that's under construction. Hmm. My name, address and country were stamped on the outside of the envelope but there was a separate US Postal Service shipping label underneath. I suspect they may be using a remailing service.
In short, each item is bagged by part. All chips are on pink foam and the entire thing was shipped in a zip-lock style bag inside a pink bubble wrap package.
The protoboard I ordered was sealed inside an air tight package I guess to reduce any oxidation.
One thing's for sure, the time it would take to individually bag these parts would certainly be worth more than $25 of my time.
I'm uploading a few pictures of the contents and will post them shortly.
Re: Tayda review (First package)
« Reply #1 on: November 07, 2013, 09:08:58 am »
Offline johnboxall
  • You do nothing, you get nothing.
    • Books, services and more:
« Reply #2 on: November 07, 2013, 10:03:58 pm »
Tayda are good for stocking up on simple things, watch their facebook page as once a month or more they have a 15% off discount code.
Offline GreyWoolfe
  • NW0LF
« Reply #3 on: November 07, 2013, 10:11:55 pm »
Was this just a parts purchase or did you get some of the whimsical kits they sell.
Tom, NW0LF
Offline deth502
« Reply #4 on: November 08, 2013, 12:23:37 am »
ive bought components from them before and have never been disappointed.  :-+
« Reply #5 on: November 08, 2013, 12:29:41 am »
I did some looking on ebay today and realized I had purchased some 16MHz ceramic oscillators from them before and I remember them coming from Thailand but shipped from Louisville, Co. I recognized the labels on the bags.
So this is what I found.
There is a Tayda2009 ebay account and TaydaElectronics account. There was also one more but I forget what it was. One ships from the US, one ships from Thailand and one ships from Singapore.
This was a stock-up session. About $25 after shipping and discount. I got 10 each of all the metal film resistors, 10 each of all ceramics and 2 each of the electros (I removed any ones with the same uF rating that were different voltage. If the price was the same I kept the higher voltage) All the electros were 16V or higher which is all I need for my basic stuff.
I'll see if I can find my invoice. I thought at first there were missing parts but I went through and it was all there.  Apparently there were things I thought I had added that I didn't (diodes and trimmer pots)
« Last Edit: November 08, 2013, 12:35:40 am by Stonent »
« Reply #6 on: November 08, 2013, 12:35:15 am »
This is what I bought:
Item   Sku   Qty
NE555 IC 555 Timer DIP-8    A-249   5
Coin Battery Holder CR2025 and CR2032    A-869   10
Stackable Header 6 Pins 2.54mm    A-1048   10
2N3055 NPN AF Amp Audio Power Transistor 15A 60V    A-110   1
2N2222A 2N2222 NPN Transistor 0.8A 40V TO-18    A-113   2
2N2907A 2N2907 PNP Transistor 60V 0.6A TO-18    A-115   2
LED UV 5mm Ultraviolet    A-1155   10
32.768 kHz Crystal Cylender 3 x 8 mm    A-1592   5
10 OHM 1/4W 1% Metal Film Resistor    A-2198   10
100 OHM 1/4W 1% Metal Film Resistor    A-2245   10
100K OHM 1/4W 1% Metal Film Resistor    A-2248   10
10K OHM 1/4W 1% Metal Film Resistor    A-2203   10
10M OHM 1/4W 1% Metal Film Resistor    A-2287   10
1K OHM 1/4W 1% Metal Film Resistor    A-2200   10
1M OHM 1/4W 1% Metal Film Resistor    A-2277   10
2.2K OHM 1/4W 1% Metal Film Resistor    A-2341   10
22 OHM 1/4W 1% Metal Film Resistor    A-2345   10
220 OHM 1/4W 1% Metal Film Resistor    A-2246   10
220K OHM 1/4W 1% Metal Film Resistor    A-2329   10
22K OHM 1/4W 1% Metal Film Resistor    A-2284   10
4.7 OHM 1/4W 1% Metal Film Resistor    A-2308   10
4.7K OHM 1/4W 1% Metal Film Resistor    A-2310   10
4.7M OHM 1/4W 1% Metal Film Resistor    A-2357   10
47 OHM 1/4W 1% Metal Film Resistor    A-2190   10
470 OHM 1/4W 1% Metal Film Resistor    A-2247   10
470K OHM 1/4W 1% Metal Film Resistor    A-2180   10
47K OHM 1/4W 1% Metal Film Resistor    A-2279   10
3.3 OHM 1/4W 1% Metal Film Resistor    A-2189   10
3.3M OHM 1/4W 1% Metal Film Resistor    A-2356   10
33 OHM 1/4W 1% Metal Film Resistor    A-2286   10
330 OHM 1/4W 1% Metal Film Resistor    A-2325   10
330K OHM 1/4W 1% Metal Film Resistor    A-2330   10
33K OHM 1/4W 1% Metal Film Resistor    A-2290   10
MPSA64 Darlington Transistor PNP    A-893   5
MPSA13 Darlington Transistor NPN    A-432   5
PN2222A PN2222 Transistor NPN 40 Volts 600 mA    A-109   20
PN2907A PN2907 2907 PNP 60V 0.8A Transistor    A-108   20
BC550 NPN Low Noise Transistor    A-213   5
BC560 BC560B Low Noise Transistor PNP    A-901   5
MPSA42 NPN High Voltage Transistor 0.5A 300V    A-288   5
MPSA92 PNP High Voltage Transistor 0.5A 300V    A-136   5
LM317T LM317 Voltage Regulator IC 1.2V to 37V 1.5A    A-177   4
LM7805 L7805 7805 Voltage Regulator IC 5V 1.5A    A-179   4
LM317LZ LM317L LM317 0.1A Voltage Regulator IC    A-500   8
L78L05ACZ L78L05 78L05 +5 VOLTS 100mA Voltage Regulator IC    A-176   10
1nF 0.001uF 100V 5% Polyester Film Box Type Capacitor    A-557   1
10nF 0.01uF 100V 5% Polyester Film Box Type Capacitor    A-559   1
100nF 0.1uF 100V 5% Polyester Film Box Type Capacitor    A-564   1
4.7uF 35V 105C Radial Electrolytic Capacitor 5x11mm    A-4504   2
33uF 50V 105C Radial Electrolytic Capacitor 6x11mm    A-4549   2
0.1uF 50V 105C Radial Electrolytic Capacitor 5x11mm    A-4531   2
1uF 50V 105C Radial Electrolytic Capacitor 5x11mm    A-4505   2
2.2uF 100V 85C Radial Electrolytic Capacitor 5x11mm    A-4511   2
0.47uF 50V 105C Radial Electrolytic Capacitor 5x11mm    A-4516   2
3.3uF 100V 105C Radial Electrolytic Capacitor 6x11mm    A-4508   2
10uF 35V 105C Radial Electrolytic Capacitor 5x11mm    A-4548   2
100uF 16V 105C Radial Electrolytic Capacitor 5x11mm    A-4514   2
22uF 50V 105C Radial Electrolytic Capacitor 5x11mm    A-4530   2
0.22uF 50V 105C Radial Electrolytic Capacitor 5x11mm    A-4512   2
47uF 16V 105C Radial Electrolytic Capacitor 5x11mm    A-4522   2
220uF 25V 105C Radial Electrolytic Capacitor 8x11mm    A-4503   2
330uF 16V 105C Radial Electrolytic Capacitor 6x11mm    A-4553   2
470uF 16V 105C Radial Electrolytic Capacitor 8x11mm    A-4521   2
1000uF 16V 105C Radial Electrolytic Capacitor 10x16mm    A-4523   2
1pF 50V Ceramic Disc Capacitor    A-507   10
10pF 50V Ceramic Disc Capacitor    A-519   10
100pF 50V Ceramic Disc Capacitor    A-531   10
1000pF 50V Ceramic Disc Capacitor    A-543   10
4.7pF 50V Ceramic Disc Capacitor    A-515   10
33pF 50V Ceramic Disc Capacitor    A-525   10
2.2pF 50V Ceramic Disc Capacitor    A-511   10
3.3pF 50V Ceramic Disc Capacitor    A-513   10
74HC02 7402 Quad 2-input NOR Gate IC    A-921   2
74HC00 7400 Quad 2-input NAND Gate IC    A-920   2
74HC14 7414 HEX SCHMITT INVERTER CMOS TTL IC    A-248   2
M74HC595B1R 74HC595 74595 8 bit Shift Register IC    A-024   5
TJM4558 4558 Dual Operational Amplifier Wide Band IC    A-1132   2
LM358N LM358 358 Low Power Dual Op-Amp IC    A-045   2
TL082 TL082CN J-FET DUAL OP-AMP IC    A-209   2
LM324N LM324 324 Low Power Quad Op-Amp IC    A-046   2
TL064 Quad Operational Amplifier J-FET PDIP-14 TL064CN    A-1134   2
HA17741 17741 IC OPERATIONAL AMPLIFIER    A-280   2
9V 9-Volt Battery Clip / Connector Snap    A-656   5
5mm Bezel LED Holder Chrome Metal    A-660   4
LED 5mm Red Super Bright    A-1554   33
Small StripBoard 94x53mm (Copper)    A-5031   1
Sorry about the layout, I didn't feel like trying to make it all nice. But it is description, stock number and quantity.
If you'd like me to get the brand or specifics on any part, let me know.
I looked at about 5 of the 74 series chips and all seemed to be TI .
Offline iloveelectronics
  • Country: hk
« Reply #7 on: November 08, 2013, 12:56:36 am »
Wow! It would easily have cost $25 just going through that list and pick the parts, let alone the actual compnent and shipping costs!
My email address: franky @ 99centHobbies . com
My eBay store: http://stores.ebay.com/99centhobbies
« Reply #8 on: November 08, 2013, 01:07:32 am »
Yeah I was wondering how I was going to sort all this stuff, but with the bags I think I'm going to just separate by base values.
I'll make a bin for 1's which will have 1, 10, 100, 1K, 10K etc and one for 2.2s, 3.3s, 4.7s etc
But I really am wondering how all this works, because I got a US Mail tracking number the following day, but then had 2 or 3 days with no updates, then magically it was in Colorado.  The labeling of my address on the package above the postage sticker makes me think they have daily bulk boxes they ship to the US to be separated.
I paid about $4.60 shipping but the package itself said it was $2.90.  Maybe they send it in bulk and mark the package something like "donated blankets for poor people" hoping it will slip through customs without being opened. Then it arrives at the remailing location to be shipped locally.
That's just a guess. I don't really know how they operate as their website does not give any indication of location. I only know from what I've heard from others and what I've seen on Ebay.
They say they offer a commission service if you submit a project to them and people buy the kit through Tayda.
« Last Edit: November 08, 2013, 01:10:28 am by Stonent »
Offline nanofrog
« Reply #9 on: November 08, 2013, 02:30:47 am »
Sounds like it's a bulk air container shipped from Tayda to AirBiz in CO. AirBiz then separates everything and labels it for shipping via USPS (labels already generated, hence the tracking number but no update until it hit USPS in CO).
Might be this company, based out of South Africa (claim to operate in 500 cities), and it seems to be the type of services they offer (international freight couriers).
Offline PedroDaGr8
  • A sociable geek chemist
« Reply #10 on: November 08, 2013, 05:55:55 am »
Tayda is awesome. I ordered a large number of parts to fix my Array Power Supply from them. Frankly their prices on TIP35C and TIP36C were unbeatable at that time (thats not including the extra 15% off). To even get close on Digikey or Mouser you were looking at needing to order qty of 2000+ in order to get similar pricing. In general, before the discount I was already looking at 50+% savings compared to Digikey and Mouser.
Also, at the time I worried about knock-off parts due to the cheap prices. So I decided to etch one of the TIP35C transitors (which I accidentally killed by my bad soldering ability):
https://www.eevblog.com/forum/chat/nitric-acid-and-a-hotplate/
Sure enough the transistor die was the right size of a power transistor and some of the internal details under the epoxy (things like the location of lines in the middle leg) match to what little I could see of the genuine before I ran out of nitric acid.
Just like your mine shipped from Colorado. I agree they must be bulk shipping to CO and then USPSing it everywhere. Likely saves them a ton in shipping costs and more importantly shipping time.
The very existence of flamethrowers proves that some time, somewhere, someone said to themselves, "You know, I want to set those people over there on fire, but I'm just not close enough to get the job done." -George Carlin
Offline george graves
« Reply #11 on: November 08, 2013, 06:17:27 am »
I didn't even know of this place - thanks for sharing!
Does anyone know if they SMD stuff(passives and components)  come on a reel?  Or bagged?
« Last Edit: November 08, 2013, 06:24:14 am by george graves »
Offline Thor-Arne
  • Country: no
  • tinker - tinker, little noob.....
« Reply #12 on: November 08, 2013, 08:12:29 am »
Just send them a email and ask for the packaging you need and they usually will be able to deliver what you need.
« Reply #13 on: November 08, 2013, 08:40:04 am »
I find that interesting because I have a couple of TO-3 2N3055 metal transistors I got for the purpose of opening them up and using them as Gamma detectors. I never thought about trying to open a TO-220 for the same purpose.
Offline PedroDaGr8
« Reply #14 on: November 08, 2013, 04:05:24 pm »
Compared to the metal case I can't imagine that the epoxy used in to-220 devices has a very high gamma cross-section. I might be entirely wrong but you may not even need to decapsulate.
Sent from my EVO using Tapatalk
Offline tsmith35
« Reply #15 on: March 22, 2014, 05:16:38 am »
I must say, having a 99.8% positive eBay feedback score for 111,000 transactions is quite impressive. I ordered from them recently and am quite happy. I was expecting a 2-4 week wait for delivery, only to receive my order within days.
Whatever they're doing, they're doing it right. Two thumbs up! :)
