Author Topic: Teardown : LEM ULTRASTAB 1ppm 600A current sensor  (Read 4013 times)
Offline TiNTopic starter
  • Country: ua
    • xDevs.com
« on: August 01, 2015, 04:38:32 pm »
Fluxgate technology current sensors madness, welcome little impromptu tear-down.
If you have interesting idea of experiments using such a device, feel free to comment!
At worklab I have 210A capable DC load and few 400-500A capable low-voltage power convertors, and 150A Tektronix clamp system, so can do something with some beefy amps.
The following users thanked this post: thm_w, Inverted18650
Offline gamer388
Re: Teardown : LEM ULTRASTAB 1ppm 600A current sensor
« Reply #1 on: March 13, 2018, 08:39:40 pm »
Thanks for the teardown and showing us what's inside that current transformer.
I use 4 of these at work with WT1600 Wattmeter from Yokogawa.
I forgot to turn on the power supply for the sensors (+15V and -15V), and now one of my CT is saying about 33 Amp RMS instead of 1A.  |O |O |O
There quite a lot of circuitry inside. I wasn't exepecting that much.
