I have a 2015 Pro model that stopped working after a power outage. I have 2 shields, one pro and one not-pro so I was able to swap the power supply (same part number on both). Both power supplies work on the not-pro unit.
I'm hoping to be able to fix this thing. I assume that there is a fuse of some type that is soldered on to one of the boards. I suspect that the fuse/problem is on the IO board but I'm not a novice when it comes to small components.
Any idea of where I should start looking?
Thanks
-G
