It all started with this post about HDMI splitters that can be hacked to bypass HDCP:
http://hackaday.com/2015/03/12/hdmi-splitter-is-also-a-decrypter/Out of curiosity, I decided to buy a cheap HDMI splitter to try the hack myself. What I got has a completely different design.
There's a PI3HDMI412AD dual output HDMI repeater, a Sil9187 HDMI receiver, and a ST microcontroller. The HDMI receiver seemed a little strange as the repeater could take the TMDS signals directly, but what info I could find seemed to indicate that it has built in HDCP decryption. Thus, it looks like it is being used as a HDCP stripper. Which basically means the unit works as a HDCP stripper with no mods needed. In fact, the DDC pins on the outputs are not connected to anything. It always gives a "generic" EDID table with a whole lot of resolutions up to 1080p60.
BTW, while trying to reverse engineer it, I looked up PI3HDMI412 and it returned the datasheet for the PI3HDMI412A, which is a HDMI switch that could only enable one path at a time. That confused me for a good while since I did connect two displays during testing and both did work at the same time. Pericom has a rather confusing part number system!
