I somtimes wonder when i see a typical american wiring job. Drilled copper bars with grub screws are one thing to terminate bunch of wires, if tightened enough it shears the solid core wires, if not it comes lose in no time. Spring type industrial connectors and din rail mounted connector blocks are better but you cant find those in residential buildings cos its expensive and no homeowner would pay for it.
However what i cant see is the use of crimped on ring terminals used with wire nuts its more secure and with proper spring washers it would never get lose, instead they losely twist the wire and sometimes the twist will untitwist beacouse of the direction which the nut is thightened. The most secure screw type connections are on the good quality mcb-s schneider electric acti 9 industrial breakers those can be thightened to a level without much effort that i basicly crimps an overhead aluminium cable those are usually multiconductor alloyed wires bundled together and pretty hard. Here i would get fired from my job if i use the method accepted in america for terminating wires for current carrying, for earthing purposes it can be used but you have to take care doing it otherwise it has to be crimped or secured with appropiate terminals mounted on the device itself.
