In NSW as a consumer we buy at a fixed rate, but not as cheap as that. either around 26c per KWH (without time of day metering) or if we move to time of day metering there are 3 different rates:
Peak - (2pm to 8pm, Monday to Friday) = 51.8C /KWH
Shoulder - (7am to 2pm and 8pm to 10pm Monday to Friday, 7am & 10pm Saturday/Sunday and Public Holidays) = 20.4c/KWH
off peak - ( 10pm to 7am, Monday to Sunday) = 11.2c/KWH
https://secure.energyaustralia.com.au/EnergyPriceFactSheets/Docs/EPFS/E_R_N_RSOT-E_EA_01-01-2015.pdf)
Solar power we currently get paid 9c per KWH for excess power fed back into the grid (so if you use it you can save 20.4 to 51.8C but if you aren't at home during the day and feed pretty well all that power back into the grid you only get 9c)
The other prices are what the power generating companies get paid by the distributors and I am being overly generous in presuming that a small scale generator would be able to get those sort of rates.....
The power grid in NSW is mostly coal fired power stations, with about 4GWof Hydro available from the snowy mountains scheme, but I am not sure what transmission losses from there are (I would be guessing fairly high) - some of the dams in the snowy mountains scheme are used for energy storage in that they pump water back up hill during the night. The snowy mountains scheme is also shared with (and closer to) Victoria so I am also not sure how much of that 4GW we would be getting on hot days anyway.
Power is also shared to some extent with other states and I am guessing that hotter days they just start firing up the brown coal stations and bugger the expense but as my earlier graph showed, on cooler days power demand plateaus around 9-10GW while peak on hotter days exceeds 14GW and it seems that last extra GW or so, is the really really expensive bit
