QuoteAnd here's a complete circuit with a 602, and a 100 MHz LO .That can be simplified by either using an outboard oscillator (or a sig gen), or utilizing the built-in oscillator + the 100Mhz crystal -> which is actually quite rare.
Here is the funcube up converter.It is almost perfect. Deadbug would be great.
Yeah, I didn't know why that circuit was using it's own LO circuit, the 602 just needs the external crystal. If I built it up I'd start with my sig gen as the LO anyway, and if I used a crystal on board , then I'd just use what I had and let the IF fall where it may, it's not important for this application, as long as it lands in the usable range of the dongle.
I would definitely give it another shot with a USB extension, some ferrites and another antenna. the PC noise makes the signals just fade into nothing and people think they are broken. And you don't even see signals. its some particularity of the fairly sophisticated internal tuner..
I just Buy and test.Quick setup:1. Download SDR sharp (IMHO the best software for SDR) http://sdrsharp.com/#download2. Do not install any driver or software from the Dongle3. Use zadig.exe from SDR sharp to install driver.4. DONE
