I've been using a weller WES51 and can do down to 0.8 mm pins with it without too much trouble. Sometimes though I need to work with 0.66/0.6/0.5mm pitch as well. Would a FX-951/FM-2032 be a good combination for this? Also, some of the tips for the standard iron that comes with the FX-951 look pretty sharp/small, would they do almost as well as the FM-2032? Is there something else that I should consider/think about?
