Now you can argue all you want but have a look at this set for instance which in dutch clearly states "first, middle and last tick" which is exactly how you should use them in tough material
And taper, plug, and bottoming taps are commonly refirst to as first, second, and last taps. I think you'll find all three of those are exactly the same past the first ten threads at most.
Yes I know what a bottoming tap is, it is used for a hole that is not all the way through and you want the tap to go as deep as possible. Therefore the underside of a bottoming tap is pretty flat. Can you see a flat bottom on the taps in my link? No you can't because they are NOT bottoming taps period.
Look at the shapes for pete sake!
And as Rob says over and over again and I second , these taps each cut a tiny bit deeper in the side of the material and the tap is only complete after the last (third) tap has been used.
And another thing look at the rings, why do you think these sets have ring markings on them? Because you can not easily see the difference between the three. With you tapering and bottom taps the difference is pretty obvious so you don't need any marking.
