I'm doing a job which involves some very small circlips; the lugs on them have holes which are under 1mm in diameter. Can anyone recommend a high quality pair of pliers (very fine circlip pliers, tweezer nose pliers, etc.) which would be small enough for such work? While there seem to be quite a lot of precision toold out there, it's hard to find any with tips under 1mm.
