Hi
I bought a basket that clips onto the side of my ultrasonic cleaner. It appears to completely block the ultrasonic action - a piece of foil left in the basket comes out unscathed, whereas the same foil outside the basket is holed in a few seconds. I estimate the wires that the basket's made from are 0.7mm apart.
If I have the right calculation, (assuming the speed of sound in water at 20C is 1480m/s, frequency is 35KHz) the wavelength is ~4mm. Does this sound right? And if so, what mesh size is optimal for allowing the waves through?
Thanks
John
