Hi Eamon
It was my blog post that you found.
EATON 9395 Power Xpert is a serious system and I think it would be hard to find someone with a installation like that, that needs that exact part. They would most likely just call Eaton for repair/service/spare parts.
I think it represent a very little value, even if taken apart for the components, especially because the skiip IGBT modules are hard to reuse due to their pressure point contacts and the electrolytic capacitors are small.
Either you strike luck and sell it at 50% of list price from Eaton (if you can even find out what that it) or I guess it will be around maximum 50-100$ worth in components to the right buyer.
