If anyone has any ideas on a reputable UPS/Inverter that would be fantastic, otherwise I'll get back to you on this particular one with some pics so you can judge for yourself. Maybe it will actually be decent. Doubt it though.
Like most everything else, you get what you pay for. High power, quality inverters aren't cheap and it's one of those things I wouldn't mess around trying to find low-end bargains if you care about your house and/or whatever is connected to the inverter.
I've done some work in RE and I would recommend you take a look at Outback Power, Xantrex, and Exeltech. They are all top-notch. If you want to spend less, I've also used and can recommend Samlex inverters. They don't have as many bells and whistles but are well made. I've also heard good things about Magnum Energy inverters (Magnasine), but I haven't used them.
I'd stay away from "modified" sine inverters and stick to those that are true sine. Most modified inverters actually output a square half-cycle pulse which can be hard on power supply input stages, and are definitely not suitable for anything that has an AC induction motor.
HomePower magazine (
http://www.homepower.com) does periodic "reviews" of inverters. You can go to their site and search on inverters. I'm calling it "reviews" in quotes since they never seem to say anything bad about anyone (sponsors, you know...) but at least it's a starting place where specs are collected and tabulated from various manufacturers.
