Our new Kickstarter campaign is LIVE ! (17 October 2016)
https://www.kickstarter.com/projects/2129383335/i-extruder-smart-solder-paste-and-fluids-dispenserBe sure to promptly get your "SUPER EARLY BIRD" reward ! (limited quantity)
I-EXTRUDER is smart Air-Free solder paste and fluids dispenser with "Pull Back" feature, and can be used for : PCB assembly and prototyping, DIY projects, crafts, professional or industrial products assembly.
It is very compact, nearly silent, light weight (110gr) and combines the precision of linear stepper motor drive technology, the intelligence of microprocessor control, and the flexibility and cost-effectiveness of 10ml plastic barrel reservoirs.
I-EXTRUDER could be used for the application of: solder paste, compounds, retainers, silicons, adhesives, epoxies, sealants, greases, lubricants...
Also, with NEW "Pick&Place" feature, I-EXTRUDER can be used as manual and almost completely silent Pick and Place tool.
I-EXTRUDER is fitted with the External Trigger jack socket and can be triggered by : foot pedal switch, IR or Inductive proximity sensor, or +3.3V or +5V impulses from CNC machine.
I-EXTRUDER consumes only 1.6 kWh/year (2h of use per day x 366 days), and could be powered from any 5V USB source (+0.5A): PC, laptop, USB power adapter, portable USB charger (battery pack).
