Thank you for your wishes, however:
You have obviously not bothered to actually check what is that dispenser for...
Oh, really ?
First, I thought that you simply joking, but now I see that you just trolling.
This is what is written in the user manual of the dispenser that you have suggested:
Wow, that's indeed is a very precise dosage of glues
by 1 CC / 1ML shots That should be perfect for DYI projects, crafts and products assembly...
So yes, I do believe that handyman's caulk gun is better.
Taking in to account the above, actually it seems that it's you, who haven't bothered at all, to check the specs.
I think, that before giving such nonsense advices and statements, you should take your time to check it first and of course compare comparable things. (
"il faut comparer le comparable")
Because comparing the 1CC-5CC shots of FISNAR manual dispenser with adjustable from less that 1mm to any size, shots of I_EXTRUDER dispenser, it's simply
stupid nonsense.
Unfortunately, I don't have a food for trolls anymore, so I will not respond to your further comments.
"the dogs bark, but the caravan goes on"...
