Everybody has a vacuum cleaner laying around, but i never saw somebody use it directly as a fume extractor. (I'm wondering why, maybe some of you have?)
In combination with a balcony the fumes get extracted right into the outside.
So you can basically use it as a very strong fume extractor without spending any extra money or building modifications.
When using a small portable cleaner even a window, where you can mount securely outside (e.g. inside a flower box), is enough.
Here is my current setup:
(Here is a short video of me attaching the small adapter on the makita and trying it out: youtu.be/7dhZXZqWFOg)
Positive:
Strong and adjustable suction.
Minimal to no additional cost for most people.
Any produced trash (fried components, shells, small pieces of wire ...) can be held near the hose and get transported into the cleaners dustbag
Downside:
Noise (Inside not so much but outside for the neighbors. So far no complaints though. I am using the quieter low power mode of the vac.)
Eventually this will be replaced but for now this is not a bad substitute.
