Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Products
Other Equipment & Products
Peizo (completed)
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Peizo (completed) (Read 2997 times)
GEuser
Frequent Contributor
Country:
Is Leaving
Peizo (completed)
on:
March 30, 2016, 03:59:11 am »
Got
Last Edit: August 29, 2016, 09:58:38 am by GEuser
Logged
Soon
DTJ
Country:
Re: Very small Peizo assistance needed
Reply #1 on:
March 30, 2016, 04:26:44 am »
I'm not exactly clear on what your requirements are:
Size: small / big / square / circular / > or < or = x mm
Terminations: flying leads / PCB pins / connector
Voltage: "AC" driven type or DC
Sound: pulsed / chime / continuous
Have you looked at the Kingstate range?
https://www.google.com.au/search?q=kpe260&safe=off&source=lnms&tbm=isch&sa=X&ved=0ahUKEwiO1fznx-fLAhVD62MKHfsjDFoQ_AUICCgC&biw=1920&bih=939#safe=off&tbm=isch&q=kpe+piezo
Logged
Smallsmt
Country:
Reply #2 on:
March 30, 2016, 08:12:57 pm »
This company is a very good buzzer supplier.
They have very small piezo buzzers but you need to add external driver circuit!
http://www.cnbuzzer.com/
Logged
Muttley Snickers
Supporter
Country:
Cursed: 679 times
Reply #3 on:
March 31, 2016, 05:20:38 am »
I just checked about a dozen or so various 13 mm units out in the workshop and they are all continuous tone, the larger 33 mm beepers are available in either continuous or beeping tones and we get then from RPG and use them for door entry alert systems which incorporate latched or timed outputs anyway, this then lets us decide on the pulse rate and duration when using the constant tone units.
Radio Parts
http://www.radioparts.com.au/product/04504055/kpe242-3v-to-16v-dc-pcb-piezo-buzzer-continuous#.VvyvJJx94dU
Logged
Psi
Super Contributor
Country:
Reply #4 on:
March 31, 2016, 05:59:37 am »
Anything you find that satisfies all those requirments will be more expensive than a raw piezo element in through hole form plus a cheap 6pin mcu.
That may or maynot matter.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Products
Peizo (completed)
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
