Hello everyone,
I managed to get my hands on a Vision Mantis, the issue I am facing is that it is a 110V AC 60Hz unit and I need to change this to 220V AC 50Hz. Changing the transformer is not a problem, the issue is that there is no info about the secondary voltage on the current transformer. From the halogen lamps I would say it has 12V secondary voltage, could anyone that owns one check what is the voltage on the jack that goes from the stand into the microscope head? Thanks!
I almost forgot, it's the original version, not the new one!
Regards,
Miha
