Do any of you guys have a recommended supplier for wall warts? I have one in particular I need to replace, but I'd rather it wasn't total crap; it'll be on 24/7.
I did replace a couple of caps in the original one, but that obviously wasn't the only problem. Maybe I'll get back to it, but a replacement will probably be cheaper than fixing it anyway.
While I'm here, what power connectors have you guys settled on for your projects? Aside from USB, I'm thinking barrel jacks aren't all bad. If you use them, what size did you decide on?
