I will agree with that. The nice thing about a line scanner head is that it has little to no distortion compared to a camera single sensor/lens combo.
I am definitely in the camp that understands that this is not a real challenge, even for very modest hardware. In 1990, I was coding software to capture/analyze 3D space for motion analysis. Similar to what animators use today for character movement capture. Reversing geometric aberrations was not particularly difficult and we were scanning an entire 3D room with 286 computers at our disposal.
Having control of lighting and using a bandpass optical filter really limits what you are needing to process. Using a line scanner is cheaper and simpler than a camera and would not require any geometry correction. In the case of a P&P, the geometry errors are fixed and predictable, so that is not much of a reason to re-invent the wheel.
Line scanners are complicated and to get a distortion free image you need a distortion free sweep across the plate and if you want to do it at both a high resolution and high speed on a rapidly moving machine your going to get mechanical distortion in the scanned images.
An optical camera can be made distortion free using very simple calibration grids and in some cases you can just spend the money and get basically no distortion optics.
A line scanner head still needs optics and try getting a cylindrical lens for your required working distance.
Another fatal problem with a line scanner is that if your processing a panel your going to need a massive line scan head to do it or cover it in multiple passes and have enough accuracy to stitch the image back together.
A line scanner is going to be more vulnerable to mechanical disturbances because the motion has to be controlled for the scan to work properly vs. a fixed camera which is not only going to be more compact is going to be mechanically one piece so it can shake all it wants but the pixels won't move relative to each other and with a fast enough exposure you can negate any vibration (Which both cameras will still have to deal with)
Also because your using a line scanner you need a similar uniform illumination system to follow it around, this is going to add a ton of bulk to the system vs a ring light around the lens of a regular camera.
Also telecentric lenses are super neat lenses.
