I'm wanting to investigate what it will cost me to buy a small PNP line for in-house small volume jobs. I'm constantly sending 20 and 30 boards away for manufacture all the time, and the time might just have come to buy a manufacturing line.
I'd like to be able to do 5000ish parts per hour, thats not so many, reliably, down to 0402 and .4mm pitch QFN's etc. i'll be looking for a stencil printer, placer and oven.
I'd consider good 2nd hand gear, or new.
Any Suggestions.
Just out of curiosity, if you are only making 20-30 boards at a time, why do you need 5000pph capacity? When you say "constantly", do you mean every couple of days? And are these large boards with a lot of parts (like dozens of separate BOM line items)?
I am a big fan of Quad 4C's. They are relatively cheap, but I would ALWAYS buy any P&P machine only after seeing it work and verifying it was trouble free (and that parts and support were available). The 4C is rated for 3600pph, but that's optimistic, as with any P&P rating. But even with a realistic throughput of 2000pph and a large board with 100 components, you're looking at 20 boards per hour.
Running a line is a giant pain in the ass. We still run a manual stencil printer and manual reflow, but I have a few 4C's for P&P'ing. Most of my boards are small, two sided and have 10-20 unique BOM items. I get them panelized in 10's and I can easily paste, place and reflow 100 sheets of 10 in a day, which is 1,000 boards.
It's a bit of a pain in the ass to set everything up for a run, so if you are just thinking of 20 at a time, I'd perhaps reconsider. I'm running around 500 boards a month and I'd estimate I am at the very bottom end of what makes sense for in-house assembly with automated machinery. I don't bother with an in-line printer and reflow... I just use steel stencils and print manually, and manually reflow as well. P&P is the time consuming part, but having the right machine (one designed to be flexible) helps. The nice thing about 4C's is they are relatively dumb. You just program it to go to X, pick, go to Y, place. So you can pick from feeders, waffle trays, whatever. And you can mount feeders wherever you like on the table.
Contrast that with my previous Fuji IP or Dynapert - they had extensive component management included in their firmware which is great for the original owner but when you're the second owner and aren't paying for a service contract, all that stuff just adds headache.
But if you want to give it a shot, look at the 4C's. But what sort of budget are you looking at, and where are you located? If you are thinking of buying new, you're probably looking at the $200-300k range for a new entry level line from a brand name supplier.
