Author Topic: Warning about older 6v soldering irons!  (Read 4421 times)
Offline OleSTTopic starter
  • Country: no
« on: May 18, 2017, 07:00:17 am »
it might sound stupid but i was trying to use and old 6V adamin soldering iron with my 0-6V adjustible power and quickly learned that i need to limit the output, at 6v the iron drew 2 amps, went red hot and then stopped working  :palm:
learn from my mistakes!
but atleast i have an ekscuse to buy a shiny new ts100!
Offline oldway
Re: Warning about older 6v soldering irons!
« Reply #1 on: May 19, 2017, 07:35:06 am »
Are you sure you could use 6V dc ?
 If you soldering iron has any temperature regulation, than you can perhaps only use AC, not DC....
« Last Edit: May 19, 2017, 07:40:35 am by oldway »
  • Country: no
« Reply #2 on: May 22, 2017, 07:44:21 am »
the box said "for automotive use" so i assumed it was meant for 6v dc becuse some older cars use 6v electrical systems?
but anyways, the iron is toast.
Offline james_s
« Reply #3 on: May 22, 2017, 06:32:17 pm »
How old was it? Cars haven't used 6V electrical systems since the 1940s and most of those have been retrofitted to 12V by now.
Offline janoc
« Reply #4 on: May 22, 2017, 06:52:59 pm »
Trabants used a 6V system too and that is decidedly postwar car.
Also many contraptions derived from motocycles use 6V electrics. It isn't very common but still exists.
Offline sokoloff
« Reply #5 on: May 22, 2017, 07:22:01 pm »
VW Beetles were 6 Volt through 1966, IIRC.
Offline james_s
« Reply #6 on: May 22, 2017, 07:24:31 pm »
Well whatever the case it's not common. This would have to be a very old soldering iron to be intended for 6V. Perhaps it's part of a system and was supposed to connect to an external controller?
Online ebastler
Offline tronde
  • Country: no
« Reply #8 on: May 23, 2017, 01:15:08 am »
Ersa minor is 6V.
http://www.tme.eu/en/details/ersa-minor/soldering-irons-and-guns/ersa/
  • Country: no
« Reply #9 on: May 29, 2017, 07:36:58 am »
Ersa minor is 6V.
it looked really scimilar except it didnt have the solder sucker. (i still have the box for it so i could possibly get you a pic of that, i might even have another one that is new in box?)
Offline NottheDan
« Reply #10 on: May 29, 2017, 09:19:16 am »
Only until 1983 IIRC. The ones built afterwards were 12V.
Offline Rick Law
« Reply #11 on: June 12, 2017, 06:45:03 pm »
I can attest to that.  I had a VW bug made in the 1960's that was 6V.
