Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Products
Other Equipment & Products
Weird pushbutton footprint
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Weird pushbutton footprint (Read 1213 times)
T3sl4co1l
Super Contributor
Country:
Expert, Analog Electronics, PCB Layout, EMC
on:
November 14, 2018, 04:10:46 pm »
http://spec_sheets.e-switch.com/specs/P010337.pdf
Why the heck did they put those spurs on it? Just make a standard gull-wing pattern with enough soldering area for everthing...
On the upside, it's very low profile, and very available right now. Seems like a reasonable part otherwise.
Logged
Seven Transistor Labs, LLC
Bringing a project to life? Send me a message!
thm_w
Super Contributor
Country:
Non-expert
Re: Weird pushbutton footprint
Reply #1 on:
November 14, 2018, 09:34:41 pm »
For additional strength maybe, pads could tear? But they are so narrow I'm not sure how much it would help.
If you are using a lot, its cheaper to tape the dome onto the PCB, but for low volume/cost non issue stuff it seems like a good equivalent.
Logged
Profile -> Modify profile -> Look and Layout -> Don't show users' signatures
floobydust
Super Contributor
Country:
Reply #2 on:
November 14, 2018, 10:52:48 pm »
The spurs seem silly, 0.2mm is not going to pull the part centered with surface tension or add more solder paste.
I had bad luck with e-switch samples, I found their plastics can't take heat and they seem to sag after reflow and the spring force plummets. Ends up to be a soft mushy click and I think that brown plastic resin deforms easily. It was a really odd experience; I didn't spec them for production.
Logged
thm_w
Print
Search
Pages: [
1
Go Up
« previous
next »
Products
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
