I think it might be helpful for others in the same situation if I reply to my own message from last year. I purchased few months ago a Ersa I-Con Pico soldering station that was on the limit of my budget (150 euros or about 200USD). It's a low(est) cost model (made in China) from a manufacturer that should know how to design a soldering station. It's very easily available in Europe. The quality was a bit of a disappointment because the unit that I received worked only few minutes. The faulty unit was replaced and the second one has worked perfectly for the 3 months that I've had it.
Good things about it:
- Reasonable price.
- Large selection tips: see
http://i-tool.de/mediothek/pdf/3ba00172_std_itips.pdf and
http://i-tool.de/mediothek/pdf/3ba00176_spc_itips.pdf- Good availability of the station and accessories (in Europe, at least).
- Warms up surprisingly quickly.
- Pleasant to use. I have big hands so I was worried about the small size ("pico").
- It really can transfer decent amount of thermal energy to the tip. I was positively surprised.
Cons:
- The biggest problem is that changing the tip requires waiting for it to cool down, unscrewing the tip part, pushing the tip from the holder and then the same in reverse. Really idiotic design. It would be easy if you could purchase more of those tip holders so that you would only unscrew it from the handle and then attach an other one but looks like they don't sell that separately as a spare part.
- Tips could be cheaper.. Chisel and point shaped 12 euros and special tips a lot more than that.
- The station has cheap plastic feel to it.
- The UI could be better. You can program temperature settings (with a memory card, weird decision from them).
- The stand could be better but it's usable.
So far I've been happy with it. If compared to the cheapest Weller WHS40 this soldering station is on a totally different level: much closer to the JBCs or high end Wellers rather than the WHS40. In actual use the only serious issue is the difficulty of changing tips.
