This thread actually got me thinking and I knocked up a DIY power supply that does everything you could possibly need for basic low voltage electronics work. This can do the following things:
* Provide any DC voltage between about 0 and 20 volts.
* Provide 6v AC @ ~1A or 12v AC at 500mA.
* Provide dual or triple rail voltages for opamps, digital logic at 100mA or so each.
* Fit in a 5x4x2" space
* Weighs less than 500g.
* Has an earth anchor.
* Short circuit protection.
* Cost less than £20.
* Doesn't eat up batteries.
All you have to do is stick a 0-6, 0-6v 6VA transformer in a box and have a few parts lying around.
* DC voltages? whop a bridge, cap and an LM317 or 78xx on the target you are testing or your breadboard.
* 6v AC? Just plug it in (great for testing tube heaters!). 12V - stack the windings.
* Dual rail/triple rail? Use 12v AC with one end grounded and the other end off a single diode, then stick a smoothing cap and linear reg on the end. Do this as many times as you need. Good for 100mA a channel easily which is fine for most op amp and HC digital work.
* Short circuit protection? Fuse! Large box of spare parts.
* Earth anchor? Earth!
Here you go:
Disclaimer: I know this is cheating
Edit: please excuse the crappy heatshrinking job.
Edit 2: ... knocked up a dual rail +/- 15v discrete supply quick (as I didn't have any negative regulators handy):
