@David Hess
No building instructions tho.
@Gregg
True, but in 2017 mercury was forbidden to use in products, this goes for most of the world.
There is other good solutions tho.
@Dundarave
That is very true, but when your homeautomation control turns the heat on and off, it is a better chance to get the desired comfort temperature around the house if the temperature input is more accurate than 3 deg.C
I am measuring about 150 cm from the floor, but I want to know if the temperature is 19, 20 or 21 deg.C (Even if it does not really matter elsewhere than in my head
I do not have any skills in electronics or software like KiCad, but with the help so far, I think I have a starting point.
What I have learned so far is that the best option may be to use a 4-wire PT100 RTD sensor and convert the signal with a RTD to digital converter.
Took me some hours to find information, but I think I have found the red line to follow.
I think I have found usable components from Farnell, but time will show.
Believe I will buy a circuit from
https://www.adafruit.com/product/3328, learn how it works and learn how to communicate with it, before I go further with trying to recreating it.
