Even in this review, I don't understand the point of timing the removal of the chip. Unless both hot air guns were set to the maximum heat output for this test, the actual side-by-side comparison is useless. And if this is the case, the board/component should also be a very challenging example with an extreme amount of heatsinking, else both guns seem to be lacking in the power department.
I mean, at maximum output, you should be able to fry some FR-4. Until you run out of adjustment, you should be able to achieve the same airflow and temp as any other gun by fiddling with the knobs/buttons. Within the desired area of interest, anyway. Maybe a more expensive gun can also be an efficient tool for removing old paint from your deck or blowing out candles from 5 feet away!? Or maybe you can set it 2 feet away from a large board with a wide-angle nozzle and effectively preheat the entire thing?!? But for typical PCB rework, the component/PCB would never be able to tell the difference, if airflow and temperature slash power output is set to roughly the same. If at this specific point where they match, one guns says 3 on the airflow and 350C on the temp, and the other says 5 on the airflow and 325C on the temp, does this mean anything? No, not really.
I can see how the heat output of a cheap station can overshoot/oscillate, a little. Temp overshoots, nichrome wire is hotter than average. This increases resistance, which decreases current. Temp undershoots. Some oscillation. But I can't imagine it to be very significant, barring some very bad AND unlucky design.
I think the main difference will come down to maximum sustainable output, ergonomics and longevity?? Perhaps a nod to precision/repeatability and warm up time / quicker to reach a stable steady state? Unless the gun has an IR sensor to actually look at the component, I don't see what all the extra fanciness is going to do for you, aside from those things. And other than the ergonomics, I don't see much of this being tested in reviews.
Seeing as I have never come close to using max or min temp or airflow on my gun, I still haven't run out of capability, AFAIC.
But why someone would need a better one? What are the advantages of it?
When I am running it at full power and the chip is not coming off and the board is not burning, I will need a different hot air station. Or maybe rig an attachment onto my 1200W heat gun.
