Author Topic: Solder Seal Wire Connectors  (Read 514 times)
Offline MacMeter
« on: August 03, 2018, 11:55:12 am »
A friend sent me the link below. I searched the forum, no results.
Does anyone have any experience with the product “Solder Seal Wire Connectors”?
https://themcdepot.com/products/solder-seal-wire-connectors
Offline todd_fuller
Re: Solder Seal Wire Connectors
« Reply #1 on: August 04, 2018, 02:39:04 am »
I don't have experience with that specific brand, but those types of splices are the bees knees. I've used the Raychem SolderSleeve products with good success. Only problem is they're usually pretty pricey if you need to use a lot of them. TE.com offers samples (+shrink tubing, etc).
Offline Bratster
« Reply #2 on: August 04, 2018, 02:50:30 am »
One thing to keep in mind is they're only good if your wire is nice clean and easily solderable.
If the wire your using it on is older or lower quality it may not solder well in which case they don't work at all.
Like if you're trying to splice some wires back together on an older vehicle.
Sent from my Fi Moto x4 using Tapatalk
Offline MacMeter
« Reply #3 on: August 04, 2018, 08:07:49 am »
Thanks, never seen them before, looks interesting.
