This one, as is? I will give it a try.
http://amzn.com/B000SL3S6Y
Yes, that's the stuff.
Any brand will do, but the content may be a bit different (more commonly is just ethyl alcohol as the active component + bittering agent). The methanol in the Kleen Strip brand makes it's activity just a bit higher without becoming too aggressive. And as it's available in any Home Depot (and other places), it's the easiest to find on a shelf IME. Top it off with reasonable prices, and it's a no-brainer for me at least (no one carries IPA in anything greater 91% in 1qt containers; cheapest this way at Sam's Club in my location). Price is ~ the same.
You can buy IPA very cheap in bulk, too. I use denatured, primarily because its convenient to buy in the can while at the hardware store, and the odor is less objectionable to me.
Best I can do is 91% for about the same money as denatured, which I opt for due to the improved performance. Convenience also plays a roll (no shipping costs = drives up the cost buying online), but the Home Depot and Sam's Club are within minutes of each other where I live, so it's a wash.
BTW, last I checked prices for the 99% stuff, it was ~$30 for a 1gallon can before shipping.
Also, if I understand it correctly, 99% IPA will eventually absorb water from the air and move towards 91%. Denatured alcohol starts and stays around 95% when open to the air.
This is my understanding as well, but I wouldn't think it's an issue unless it's open and left out (would think a properly sealed metal container wouldn't let moisture in).
If I try to thin my RA with too much denatured, some solids precipitate out of solution. I have some 99% IPA somewhere, but I haven't tried it, yet. I have some lighter fluid, which I shall have to try, as well.
Try adding some acetone instead, and see if that doesn't solve the precipitate (xylene should do too).
I haven't tried a Bon pen, yet. I have made do with what I have on hand. If you tie a bit of twine into a knot and run the end through a plastic syringe tip, you get a decent brush tip that can't accidentally squirt flux 2 feet through the air. Then you can melt the plastic with hot air and smoosh it down around the knot, so the brush can't back out. A dip brush works great for passives, but with the syringe brush, you can lay down thicker beads for the IC pads. I am sure you can do the same thing with the Bon pen by squeezing it.
A syringe with a needle does pretty well too at dispensing precise amounts from what I understand (makes sense to me at any rate). They make inexpensive
brush bottles specific for flux dispensing (not as much control as a Bonpen), and you could also use a nail polish type of brush bottle (can get new empty ones on eBay cheap).
