A while ago I was looking at small power drivers, and bought a few, including the
wankwowstick.
The problem with all of them is they are too slow. They're mostly designed around the false assumption that what you want in a small driver is a big driver, only smaller.
Big drivers are designed for high torque, for woodscrews, selftappers, and nyloc nuts on machine screws & bolts.
For larger machine screws & bolts with normal nuts, impact drivers are a faster alternative.
For small machine screws, the only reason to use a power driver is to get better speed - torque is simply not an issue as hand-torque is more than enough.
What you ideally want is something a similar shape and size to a normal non-powered screwdriver, with a shaft that by default is locked, for final tighten or initial loosen, then a fast screw/unscrew with minimal torgue ( and hence low weight/small size) the to do the rest of the thread.
You also want an adjustable torque stop, and minimal rotational inertia, so 1/8" not 1/4" hex bit size.
I've yet to find something ideal, the closest I've found is the Panasonic EY-4710
This has a really good torque stop (stops dead, doesn't just bang against a limit, which is unusual), which will go low enough to do things like 3.5mm terminal blocks.
It is a little on the large size, and the top speed could do with being about 2x what it currently is. As it uses 1/4" hex bits, rotational inertia is slightly high for smaller screws, especially with a magnetic bit holder. The light is also pathetic, an the charger is huge and clunky. Still a very useful tool and the best dedicated power screwdriver I know of.
As for the Wowstick - complete and utter wank. Don't even think of wasting money on it. Stupidly slow, offers no noticeable benefit over a manual driver, no torque stop, no soft-start, charger is crap (contacts onto aluminium body by gravity, giving somewhat unreliable contact).
Some idiot is clearly trying to Apple-ise tools - if they had done a decent job of it it might justify the price, but no, they've just taken a turd and applied some polish and packaging with no improvement to the functionality.
If you want to spend money on a nice screwdriver, get the Panasonic.
