Author Topic: X-ray fluorescence spectrometer teardown  (Read 2470 times)
    • Mike's Electric Stuff
« on: April 20, 2014, 10:02:03 am »
Video of a more modern, but very similar version :
« Last Edit: April 20, 2014, 10:36:29 am by mikeselectricstuff »
Day Job: Mostly LEDs
Offline han
Re: X-ray fluorescence spectrometer teardown
« Reply #1 on: April 20, 2014, 10:16:47 am »
Awesome :-+
« Reply #2 on: April 20, 2014, 11:47:45 am »
Very nice Mike. A use for that detector is to connect it to an ADC and use it to count the background radiation in the shop, and bin the values so you can get an idea of what particles are in the area. Yoy probably will be able to discriminate against the assorted energies quite well and divide into cosmic rays, local alpha particles and possibly even find neutrino decay in there as well.
« Reply #3 on: April 20, 2014, 02:10:04 pm »
Some bits from it on ebay :
ttp://www.eevblog.com/forum/buysellwanted/xy-steppertable-proportional-counter-tube-from-x-ray-fluorescence-spectrometer/
Offline LapTop006
« Reply #4 on: April 20, 2014, 04:16:06 pm »
That X-Y table would be a lovely base for a 3D printer (or mini-router as you suggested), shame the cost to "pick up" would require several thousand pounds in flights.
Online amyk
« Reply #5 on: April 21, 2014, 11:46:59 am »
Interesting. The datasheet for the tube says "filled with dielectric oil", not "silicone jelly".
Careful with running that x-ray tube unshielded...
