Author Topic: 2ghz pulsed transmission?  (Read 2558 times)
Offline CopperConeTopic starter
  • *knock knock*
« on: August 15, 2017, 05:56:20 pm »
I have a bicone hooked up to my SA and I found a weird pulsed signal on almost exactly 2GHz. It appears to be a very slow amplitude(on off) modulation, almost like a beacon. Like it turns on every 2 seconds for a second and turns off. Very slow. Literary like human seconds.
Any idea what this might be? I looked at it for a while and it appeared to be repetitive.  :o
« Last Edit: August 15, 2017, 05:58:36 pm by CopperCone »
Offline Karlo_Moharic
  • Country: hr
Re: 2ghz pulsed transmission?
« Reply #1 on: August 15, 2017, 06:36:13 pm »
Check you router or wireless modem , sometimes they can have certain features enabled. For example on my router there is a WiFi feature that in a way works like a beacon for WiFi reciever.
Offline Yansi
  • STM32, STM8, AVR, 8051
« Reply #2 on: August 15, 2017, 06:44:03 pm »
Wifi is not 2Ghz, so... what?
  • *knock knock*
« Reply #3 on: August 15, 2017, 06:58:09 pm »
yes, it does not appear to be a frequency related to cell phones or wifi. appears to be fairly powerful too.
I will try to find it again. I saw it last month and its been bugging me since.
ok, thats different. it appears to be a bunch of spikes when I center around 2 GHz with 50MHz bandwidth. Kind of looks like some kind of digital communications.
Before there was just a pulse that went on and off. Maybe I remembered the frequency wrong...
What is the purpose of beacons anyway? I figure anything computer related would be alot faster then a few Hz frequency.
« Last Edit: August 15, 2017, 07:09:43 pm by CopperCone »
Offline StillTrying
  • Country: Broken Britain
« Reply #4 on: August 15, 2017, 07:32:06 pm »
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #5 on: August 15, 2017, 08:12:06 pm »
There's GSM bands at 1850.2 – 1909.8 and 1930.2 – 1989.8 (MHz, uplink and downlink respectively).
I've seen GSM-850 around here, that looks like a picket fence of carriers with digital (flat topped) bands appearing within them from time to time.
Hmm, I didn't try demodulating it, I should.  It ought to be that freaking bit-bit-beep-bit-bip GSM sound that bleeds into freaking everything...
Seven Transistor Labs, LLC
Offline metrologist
« Reply #6 on: August 15, 2017, 08:24:00 pm »
This is what I get off my specially tuned 2GHz paperclip.
Offline w2aew
    • My YouTube Channel
« Reply #7 on: August 15, 2017, 08:36:02 pm »
Most likely cellular downlink (tower to handset).
FAE for Tektronix
Offline TheSteve
  • Living the Dream
« Reply #8 on: August 15, 2017, 08:59:19 pm »
I doubt it ever turns off. Check out band 2 LTE - 1930-1990 MHz, as w2aew mentioned this is the cellular base station to handset link.
If it is LTE you can expect carriers 5/10/15 or 20 MHz wide.
VE7FM
  • *knock knock*
« Reply #9 on: August 15, 2017, 09:47:45 pm »
Yes, I see something similar on those frequency ranges, but with more resolution (maybe its my RBW?)
This signal I speak of was just a spike that appeared and disappeared. I believe I even put my instrument into receiver mode (0 Hz span) to check for modulation. It just appeared and disappeared with a very low frequency in the seconds.
When I look at the cell/wifi bands, I see spikes that dance around (probably because its only 10mS maximum update rate). I assume each is a data channel that someone is using. 2 modulated carriers per connection right, so its duplex. Digital stuff looks like... well its doing something fast.
 This thing was slower then someone keying morse code.
« Last Edit: August 15, 2017, 09:50:04 pm by CopperCone »
Offline metrologist
« Reply #10 on: August 16, 2017, 12:21:47 am »
50 MHz span and 30kHz RBW, IIRC. Not sure about VBW.
Offline Lord of nothing
  • Country: at
« Reply #11 on: August 24, 2017, 11:10:04 am »
What I know in the US the use ~2ghz for Sat Radio and Sat Phones.  :-//
There are more thinks like Zigbee for example.
Made in Japan, destroyed in Sulz im Wienerwald.
