High bandwidth scopes generally have a 50 ohm option. For low bandwidth scopes (say up to 200MHz), then the solution posted by xzswq21 of using a t-converter and a 50 ohm termination probably works ok. Though the response by minicircuits is probably right as you would have 50 ohms in parallel with the RC of the input to the scope.
My scope does have 50 ohm input as an option but it is limited to 5Vrms before damage so sometimes I've used a T-connector and 50 ohm termination on the 10Mohm input when working with signals I suspect might be quite large.
