Author Topic: 869.4MHz Bandpass  (Read 2711 times)
Offline nighthunterTopic starter
  • Country: sk
869.4MHz Bandpass
« on: December 12, 2016, 09:46:31 am »
Hi everybody. I am viewing EEVBlog for a longer time and learned a big from here, but now i have some problem. I am working on a TRX based on RFM12BP, but on the output i am getting a lot garbage on the whole range from 100MHz to 1Gig. I am using 869.400MHz (869.4MHz, while it is a long range device and i need to go to the limit of output power (500mW). The question is coult someone help me to design a bandpass filter for the antenna? In and out impedance is 50Ohms. The spectral graph that was measured is attached.
Offline Lord of nothing
  • Country: at
Re: 869.4MHz Bandpass
« Reply #1 on: December 12, 2016, 11:30:36 pm »
Gratings from Austria.  :-+
Do you look on Ebay? Some Ebay seller sold "cheap" Filter for common Freq Bands.
Maybe you also would ask here: forums.radioreference.com/
Made in Japan, destroyed in Sulz im Wienerwald.
  • Country: sk
« Reply #2 on: December 13, 2016, 06:08:48 am »
Hi, yes ive searched on ebay, but did not found anything that is suitable for me. I will ask on the radioreference forum.
Offline LaserSteve
« Reply #3 on: December 15, 2016, 12:54:37 am »
How much space do you have?
Most SMD filters cannot handle the power level you suggest.
How many units do you need?
This is where I would start....
http://www.hparchive.com/Bench_Briefs/HP-Bench-Briefs-1989-01-03.pdf
If I only needed one or two:
http://www.changpuak.ch/electronics/interdigital_bandpass_filter_designer.php
or get some US 850 Mhz cellular band filters on Ebay
Lets narrow down some production  parameters, shall we? One , Two, or Many?
Steve
« Last Edit: December 15, 2016, 12:56:38 am by LaserSteve »
"What the devil kind of Engineer are thou, that canst not slay a hedgehog with your naked arse?"
The following users thanked this post: nighthunter
  • Country: sk
« Reply #4 on: December 15, 2016, 06:20:42 am »
Hi LaserSteve. The problem is that now there are only 4 units (total there will be about 25 of this units), but i need to certify it. I have about 8-9 square centimeters in a place about 2cmx4cm in size. Would you be able to help me with this?
Offline daqq
  • Country: sk
    • My site
« Reply #5 on: December 15, 2016, 11:14:33 am »
Take a look at what minicircuits is offering - they have a nice range of bandpass filters. Such as:
http://194.75.38.69/pdfs/CBP-840C+.pdf
Also, wow, that's a whole lot of extra signal. How and where are you measuring this? On the antenna output, or just by air?
Also, nice to see another Slovakian fellow here  :)
« Last Edit: December 16, 2016, 07:57:06 am by daqq »
Offline LaserSteve
« Reply #6 on: December 15, 2016, 05:50:26 pm »
Do you have access to CNC machining?  If Not,  CBP-840C+ is not a bad option for 25 units.
Ideally filtering is done before and after final amplifier, may we have more details about your RF chain please?
A two Dollar ceramic SMD filter from Digikey some place before your final amplifier may reduce your problem significantly.
Steve
  • Country: sk
« Reply #7 on: December 16, 2016, 09:02:50 am »
The spectrum was measured right on antenna connector - so direct coupled with spectrum analyzer. I ordered som of the ceramic filter, but will it handle the output power of +24dBm? CNC machining is right by me now a problem, but i have a workshop nearby.
Offline daqq
  • Country: sk
    • My site
« Reply #8 on: December 16, 2016, 11:28:41 am »
Try contacting the manufacturer - minicircuits has a very good support line.
Offline LaserSteve
« Reply #9 on: December 16, 2016, 09:29:48 pm »
Do you have a schematic or block diagram? It helps to know where to put the filters.
Steve
