Hi guys,
I need a cheap way to get a frequency adjustable (digitally, so PLL) 9 - 10 GHz microwave signal - I don't need any particular signal strength, just a signal at anything above around -10dBm, just so a peak of a known frequency will show up on a spectrum and I can tune a different oscillator against it.
Now, I've been looking, there's a few PLLs that should be able do this, with pretty mundane components around, such as:
http://www.st.com/resource/en/datasheet/stuw81300.pdfhttp://www.analog.com/media/en/technical-documentation/data-sheets/ADF5356.pdfOr maybe something with a lower frequency and then pass it through a doubler...
The signal from this would then go directly onto a small antenna, keeping the microwave stuff confined to a very small area of the PCB.
Now, onto the iffy bit - would it be OK to use an FR4 PCB? 4+ layer, 0.1mm between top and internal.
The ADF5356 datasheet specifies:
Do not consider using FR4 material because it is too lossy above 3 GHz
But seeing as I'm not very interested in the actual output power, and the microwave stuff would be confined to say, 20mm of trace, this should not present much of a problem? Or is there some extra problem I'm not seeing? Since the problematic parts (VCO, buffers, PLLs) are already on chip, they shouldn't mind the material of the PCB at all.
Thanks,
