For a while Ive been looking for a cheap VHF/UHF LPDA to mount outdoors on a rotator in a vertical orientation. Unfortunately, communications grade LPDAs are insanely expensive. (Probably because they are used in RFI compliance testing?)
However, what appear to be almost identical antennas are used for TV, and it seems as if they are more common in Australia than in the US. Anyway, i was wondering if any of you see any that look "better than average" if maybe you could pass on the URL..
The problematic feature is vertical mounting ability.
Most LPDAs, meant as they are for TV use dont have a vertical mounting option, some do. It seems like I might be able to source a fairly robust LPDA this way, or at least get most of the parts together to make one cheaper than building my own. The LPDA is one of the best broadband directional antennas.
Thank you.
