Aluminum foil is thinner than 1oz copper foil (PCB stock, say), and higher resistivity besides, so it will only be effective down to higher frequencies. This doesn't matter much for, say, VHF+.
I wish McMaster had tin plated steel, I'd get a 24x24 sheet of that. Otherwise, there's just the little craft squares at the hardware store, overpriced. It's easy to solder, easy to form, strong for its thickness, and somewhat effective magnetic shielding down to DC, as well as to lower AC frequency than a comparable piece of aluminum (because skin effect).
