Author Topic: advice on buying second-hand network analyzer [title edited]  (Read 5870 times)
Offline bug13Topic starter
« on: April 29, 2017, 02:47:06 am »
Hi guys
I want to get more hand on, and learn about more about antenna matching and tuning, so I need a VNA. New ones are too expensive for me, so I want to get my hand on a second one. second-hand one. (didn't know why I typed second one, doh!!)
I see this on ebay:
Keysight Agilent HP 8711C 300 kHz to 1.3 GHz
http://www.ebay.com/itm/Keysight-Ag...530939?hash=item28223416fb:g:6toAAOSwYIxX~jTQ
correct link:
http://www.ebay.com/itm/Keysight-Agilent-HP-8711C-300-kHz-to-1-3-GHz-Network-Analyzer-30-Day-Warranty-/172372530939
What do you guys think? I would love you hear your advice/suggestion before parting my money.
Cheers.
James
« Last Edit: April 30, 2017, 12:12:41 am by bug13 »
Zhuhua Wu
A guy who creates stories to tell machines to do stuff.
Offline KD0CAC John
Re: advice on buying second-hand network analyzer [title edited]
« Reply #1 on: April 29, 2017, 02:13:03 pm »
You need to double check your link , it does go to eBay - but no results ?
There is other options that can be new and cost less than either $500 or $1,000 , many are tied to using a computer to use .
For that range , one is the miniVNA Tiny   http://miniradiosolutions.com/54-2/
I have had the miniVNA Pro for some yrs. , not as high in frequency coverage .
Offline Teuobk
« Reply #2 on: April 29, 2017, 09:41:55 pm »
Are you maybe linking to this one?
If so, a few thoughts:
  • That's a 75 ohm input impedance model, so if you want to use it to characterize 50 ohm devices you'll need a "minimum loss pad"
  • The HP 8710 series of VNAs provides decent performance. Not super-high performance, but totally fine for most things you'd want.
  • That one has a T/R test set, so if you want to do full S-parameter measurements, you'll need to do some cable swapping
  • The full CLIP (schematics, etc.) for the 8711C is available, so if something were to break, you'd have a good shot of diagnosing and fixing it
I have a 8714ES, and I've been very happy with it (after I repaired it).
« Last Edit: April 29, 2017, 09:43:59 pm by Teuobk »
« Reply #3 on: April 30, 2017, 12:13:34 am »
Hi John,
miniVNA look interesting, I think it may be better suit for me, thanks for the info. PS: the link is fixed.
Zhuhua Wu
« Reply #4 on: April 30, 2017, 12:16:17 am »
Hi Teuobk
I think the 75Ohm impedance really turn me off, all the stuff I am interested in are 50Ohm, thanks for pointing this out, it helps me a lot. Thanks for your replay!!
Zhuhua Wu
Offline BigBoss
« Reply #5 on: May 16, 2017, 12:43:41 am »
It's not a VNA, it's just a Scalar Network Analyzer.You cannot measure impedances in complex form on the Smith Chart. ;)
That's why it's very cheap..
Offline Teuobk
« Reply #6 on: May 16, 2017, 05:09:34 am »
Interesting. I checked the datasheet, and you're correct: the 8711C is a scalar network analyzer. The 8712 and 8714 are proper vector network analyzers, with Smith charts, complex impedance, etc., so I had assumed the whole 8710 series were VNAs -- nope! Good to know.
Offline bozidarms
  • Country: at
« Reply #7 on: May 16, 2017, 10:15:11 am »
give a try to - 1.3 GHz DG8SAQ Vector Network Analyzer   VNWA3E  -,
it is more than adequate.
Regards
Offline BigBoss
« Reply #8 on: May 16, 2017, 02:59:20 pm »
If you can find old stuff 8720C, it's really good VNA ( I used for years) but it may be a bit pricey.
Offline KJDS
    • my website holding page
« Reply #9 on: May 16, 2017, 05:16:40 pm »
The 8711C and the 8713 are vector network analyzers, however they only displays scalar information. It is possible to suck the vector info from the GPIB port.
« Last Edit: May 16, 2017, 09:53:23 pm by KJDS »
Offline TheSteve
  • Living the Dream
« Reply #10 on: May 16, 2017, 07:49:27 pm »
You can also convert the 8711x series to a 8712x with a small firmware change to a socketed chip.
VE7FM
Offline BigBoss
« Reply #11 on: May 17, 2017, 04:58:56 pm »
If it's so why this equipment does not show the vector information on the screen??? I don't think that is so easy.
Vector information is more complicated than scalar one.The equipment should measure "the Phase" that is more complex.
Offline KJDS
« Reply #12 on: May 17, 2017, 05:34:06 pm »
You'll have to ask Keysight why it doesn't show the phase data on the screen.
Offline TheSteve
  • Living the Dream
« Reply #13 on: May 17, 2017, 07:59:37 pm »
8711/8712 are the same hardware just as 8713/8714 are. The display of vector information was simply disabled on screen on the cheaper models. As was already stated it has always been available via the GPIB port. Or a change to the internal eeprom will upgrade an 8711 to a 8712 or an 8713 to a 8714. With the upgrade all vector information is available on screen.
VE7FM
Offline hendorog
« Reply #14 on: May 17, 2017, 08:10:04 pm »
FWIW I made an offer a while back of $430 on that auction. Seller never came back to me.
Offline chrisl
« Reply #15 on: May 18, 2017, 04:12:36 am »
Looks like this is very doable... no idea how.
http://minolta1.cninet.cz/HP8712C/
