A discussion on another thread got me thinking. I am building an APRS tracker using a clock chip as my rf source and modulator. The output is an FM modulated square wave at 144 MHz and 3.3v (biased to 0-2.5V). Obviously it will be low pass filtered veloce going to the antenna to kill the odd harmoics. But it needs to be amplified - I'd like around 250-500mW, ideally,
My original plan was to use an off the shelf MMIC IC, but some comments on the other thread mentioned Class E amplifiers and amplifying the square wave itself. I started reading about them (can't say I understand most of it yet), and it looks like a lot of the work and components needed for a Class E are specifically for dealing with the harmoincs. It's almost like they are taking the input sine wave, turning it square, and then back to sine. Which got me wondering:
Is there a good way to just amplify the square wave to begin with? Seems like it should be easier and more efficient than amplifying a sine. Maybe a push-pull with no worry about crossover distortion? Obviously low pass filtered afterwards.
I've thought about using a logic level shifter, but the ones that go to 144MHz seem to be limited to 5V, which is a bit lower than I'd like.
Thoughts? Are there standard ways to amplify a square wave?
