I think Anritsu has made some of the best VNAs and they seem to have been making more investments into the ShockLine series. The B models are a new upgrade and this instrument line shares much of the same core software application as the higher class VectorStar instrument line, which has been around for a while. I've never had a problem with software stability. These product lines are designed, built, and tested in the US facility and there should be great support. Product quality should be excellent.
That just leaves the functional specs which you could compare with other competitive models to make sure it will do what you want it to do. The measurements you listed are product feature highlights, so it should be a good candidate.
