hi,
Not certain what the problem is, but when I input an appropriate signal, I get No response from the 710a SA.
My guess is that the I/P amp is dead or the I/P Attn is not working.
All other functions appear to be working on the front panel.
The Calibrator O/P, when fed into a different SA, is spot on.
Not sure where to start ... Does on have to take apart the inner shields to get at the I/P amplifier & Attn circuits for testing ?
Or, can one simply reach appropriate test points when the outer case is taken off ?
