I'm looking for a simple project where I can send some data over VHF or UHF. Best would be a kit where you solder it together, then I can attach it to a home made antenna. I'm just looking for it to do something simple like send the temperature, nothing in particular, I just want to learn how to send data, then experiment with how far I can put it with as little transmitter power as possible. Or even just a beacon. I found some beacon projects but they are on Shortwave bands and I want something with a small antenna.
