I didn't know anything about YIG oscillators, but they looked like they'd be fun to
play do serious experiments with. I've bought 4 oscillators, 2 filters, and a synthesizer built around a YIG oscillator. They all worked. The oscillators are a cheap way to generate very high frequency signals at rather high levels (+10 to +20 dBm). Mine cover the range of 1 - 12 GHz.
It's best if you can find data on a unit. The supply voltages are all non-standard and different from model to model. FM coils are a nice feature (not all units have them), particularly if you want fine frequency control or want to use the oscillator in a synthesizer.
Make sure you know the difference between a YIG oscillator and a YIG filter! If there's more than one SMA connector, it's almost certainly a filter!
Prices have been rising lately, but there are still good deals out there. Filters are cheaper than oscillators. Units with a driver are more expensive than units without, but info on units with drivers seems to be harder to find. The drivers make it more convenient, but aren't really necessary.
A few years ago I threw together a zip file with various documents on YIG oscillators. Help yourself.
http://www.mediafire.com/file/6v0db7crbkbb943/YIG.zipEd
